Re: Suspensión de Highland en Legacy
« Respuesta #15 en: 28 de Febrero de 2024, 10:15:32 pm »
En foros americanos hay gente que ya esta mirando de poner los amortiguadores ya que es elemento que difiere respecto al legacy. Se comenta que es similar a los Koni con FSD.
« Respuesta #16 en: 28 de Febrero de 2024, 10:20:37 pm »
 Gracias por la info, ¿no cambian muelles, o va todo junto?
¿Silenblocks?
« Respuesta #17 en: 29 de Febrero de 2024, 06:56:55 pm »
¿Silenblocks?
Lo estan comprobando todavía, pero parece que hay muchas piezas compatibles. Hay que tener en cuenta que es un negocio pues hay muchos model 3 y model Y que quieren ese “update”.
mmick
  • 608
« Respuesta #18 en: 29 de Febrero de 2024, 08:24:27 pm »
Es cierto, yo soy uno de ellos  ;D
« Respuesta #19 en: 29 de Abril de 2024, 10:30:06 pm »
En USA ya estan probando y por lo visto buenas noticias: copio/pego.
I just finished installing highland springs and dampers to my ’22 M3 LR. It has been over a month since I test drove a highland so my memory might not be accurate, but the improvementfrom stock is huge. Swallows larger bumps much better and does not have any jerkiness over smaller imperfections. It still has suspension ‘sound’ eg when there is a bump you can still hear suspension ‘thumps’ when it rebounds. This might improve over next weeks as the car is noticeably higher than before, new springs need to settle. I would say this upgrade gives 90% of the highland suspension.
I previously tried KONI Active frequency dampers with original springs. I would say it was mostly as harsh as original. There might have been a defect in the front KONI dampers, in 2000-3000km they developed a clunk and I retorqued everything with no improvement. Switched back to original dampers and clunk was gone.
Part numbers for highland suspension:
1344362-00-D Front Left Spring and Damper assembly (185€)
1344362-01-D Front Right Spring and Damper assembly (185€)
1344462-00-D Rear Damper (140€/piece)
1344472-00-B Rear Spring (120€(piece)
« Respuesta #20 en: 30 de Abril de 2024, 09:15:05 am »
Pues esas pruebas además podrían arrojar datos muy buenos para ver si el tema de las vibraciones sufridas en algunas unidades de los HL son debidas a dicho conjunto de amortiguadores y muelles, o montadas en varios legacy no aparece dicho problema.
